Conditional Formatting
I can only get three conditions, can I get more?
RE: Conditional Formatting
you could combine multiple conditions via equation, but you're limited to 3 formats as far as I know. I'm sure it could be done in vba
You can also have a different default format for the cell (which applies if none of the three conditions applies), effectively giving you four formats altogether. That's as many conditional formats as you can get without using VBA etc, as far as I know.
The only other thing I can think of is using a custom number format to distinguish between negative, positive, and 0 values, and use conditional formatting on top of that.
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
