Activation differences-SW2006 and SW2007?
I am trying to work out what version of SW I should put on my home computer.
I prefer not to transfer the license forward and back if I can.
Is there an advantage in loading the SW2006 Sp4.1 on the home machine over SW2007 in that I don't need to transfer the licencse?
Or do I now have to transfer the license on both versions?
RE: Activation differences-SW2006 and SW2007?
If you have a floating license then you would have to transfer the license via FlexLM regardless of year.  It's my understanding that we can still run 2007 on our home machines.  Although, I have not tried this since my home computer still has windows 2000 pro.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right."  -- George Best
Thanks for your replies.
Do I have to do any transfers when I leave work and do I have to transfer it back to work when I am finished at home?
Thanks Scott,
What is a HUL?
Home Use License
We are converting half of our standalone licenses to floating license due to useage rates.  We were told by our VAR that the only way to use these at home was to via FlexLM license check out.
Heckler
      o
  _`\(,_
(_)/ (_)
Heckler, your VAR can send you individual serial numbers for home use.....as many as you have network license. You hav to sign a home license agreement.
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP3.1 on WinXP SP2
Heckler,
Gilashard is correct, your VAR can supply an application form that they send to SolidWorks for Home User Licenses.  You are entitled to as many HUL's as you have Network Licenses of SolidWorks.
We just converted our standalone seats and added a few more seats of SolidWorks, 6 total, as network licences.  I have a HUL serial number from SolidWorks that will allow for 6 activations of HUL licenses.
This is a bit more work for the VAR as they need to get you the application and fax it back to SolidWorks, who will then take a week or two to issue the HUL serial number.
Anna Wood
SW 2007 SP2.2, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
