Driveline shear severities
Shear stability requirements for gear oils are usually higher than for automatic transmission fluids. Why is this?
RE: Driveline shear severities
the amount of fluid also plays a role, in an automatic most of the fluid goes into the torqueconverter, but ofcourse a larger amount of flluid is circulated and therefore the "shearrate per volume" is far lower then in a manual gearbox that contains usually somewhere between .45 and 1.5 litres of oil.
