tune ups & tire life 1950 & now
6
Need approximate figures for tire life and frequency of tune ups on 1950 automobile and current automobiles.   Use is for a speech showing advances in material science as they apply in everyday life.
Thank you,
Tom Walz
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
RE: tune ups & tire life 1950 & now
It used to be more or less standard that you'd change plugs and points and tires and rebuild the fuel pump every 30,000 miles at most.
Now, typically,
Good tires go > 70,000 miles.
Crimped mechanical fuel pumps go > 70,000 miles.
Electric fuel pumps go, well, indefinitely.
Most car engines don't even have points.
Plugs go >100,000 miles.
Even oil change intervals are way up.
There really isn't such a thing as a tune-up anymore.  They're still sold, but they now comprise changing oil and a couple of filters and checking some stuff that's unlikely to be broken.
Mike Halloran
Pembroke Pines, FL, USA
You /had/ to grease the suspension every 1000-1500 miles
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
And change plugs, ignition components, etc. every 10-20K for some vehicles in the 60's.  Not too familiar with vehicles from the 50's, its a tad before my time.
-Reidh
Don't forget the progression of tires from natural rubber to polyester to steel belted radials..America was the last on board with radials until the fuel economy forced manufactures to switch  from there bias ply polyester tires to radials.
Pre polyester tires were good for about 15000 mi and ~ mid 60's when bias ply polyester tires came around they doubled that and ~ mid 70's when radial tires came they doubled the mileage again..Not to say anything about the performance gains.........
Cheers
I don't know anything but the people that do.
Thank you, Gentlemen.
If I could impose further, would you mind checking the following?  I would appreciate any comments you cared to make.
Tom Walz
Advanced Carbide Grades for Woodworking
Technology in the woodworking industry is dominated by mechanical engineers and they have done incredible things.
What our industry has lacked is a full exploitation of advances in material sciences.
Tungsten carbide tipped saw blades for woodworking emerged commercially in the 1950’s and 1960’s.   At that time the “C” grade designations were new.  The “C” grade concept was developed by Buick and the US army in World War II to specify carbide by the appropriate use.    The first saw blades were built with these “C” grades and they are still being used today.   They are better made than they were fifty years ago but they are still fundamentally the same material.
Tungsten carbide research and new grade development is almost exclusively devoted to steel cutting because that is where the money is.   In the past twenty five years there have been a couple carbide companies who have addressed the woodworking market with new grades but.  In both cases this woodworking emphasis only lasted a couple years when they realized that their dollars were much better devoted in other areas.
To give some idea of the benefits possible with material science advances in the past forty or fifty years consider what has happened to automobiles.
Fifty years ago:
Tire ads promised long wear and that you would love the second 10,000 miles.   Now good tires go up to 70,000 miles in stead of 20,000 miles.
Tires have come from natural rubber to polyester to steel belted radials.  Pre polyester tires were good for about 15,000 miles and mid 60's bias ply polyester tires were good for about 30,000 miles.  In the mid 1970's radial tires doubled the mileage again to the current 60,000 to 70,000 miles.  In addition there was a great improvement handling and performance.
Fifty years ago you had to do a tune up and change points, spark plugs and maybe other ignition components, etc. every 10,000 to 20, 000 miles for vehicles in the 60's.  Now plugs can go 100,000 miles and most cars today don’t even have points.
To make it simple, figure 100,000 miles at 60 mph and 1,000 rpm then you get spark plugs that survive a million explosions in a highly corrosive atmosphere.   In actual use a spark plug survives high temperature, high pressure, corrosive atmosphere and extremely rapid compression – tension cycling several million times in 100,000 miles.
Mechanical fuel pumps would go maybe 70,000 miles and now electric fuel pumps go, well, indefinitely.
Fifty years ago you had to grease the suspension every 1000-1500 miles.  Now you don’t grease it at all.
Thomas J. Walz
I don't have any problems with that.
Mike Halloran
Tom--the tire subject needs come clarification. Tire rubber went from natural rubber to a blend of natural rubber and various synthetics. No polyester. The polyester is the reinforcing fabric, which has gone from natural fibers, to nylon, rayon, polyester and Kevlar. Tire construction went from bias ply to bias belted and radials. In the U.S. the bias belted tire was an interim step prior to going to radials.
Your number of plug firings is off by a couple orders of magnitude.
Agreed.  Estimate (3000 Rev/min*60 min/hr*100,000 miles)/(60 miles/hr*2 revolutions per spark plug fire) is approx 150,000,000 firings.  This is for a four stroke.
-Reidh
Thank you all for your help.
Tom
Thomas J. Walz
