File not found
File not found
Hello, I just pulled up an assembly and most of the parts are not showing. I look at the edgebar tool and it tells me the parts are unloaded. The parts still exist on their own in the respective folders, just not in the assembly. How do I load them again? Thanks!
Al Guim
www.contech.com
RE: File not found
when the part in question shows an empty dice as icon then
the part is hidden. Select the part or the top level asm
do an RMB and select show (single part) or show all (asm).
When the part in question shows a dark grey dice as icon then
the part is inactivated. Select the part or asm RMB -->
activate
It may also happen that the part(s) in question are surface
models only that won't show up. In this case select the part do
an RMB and select Show/Hide Component --> Surfaces
A missing file will be indicated by a question mark as icon
dy
