cores and shear walls sap and or etabs modelling
hello...
1 : when modelling cores and or shear walls , their are 2 methods to use..structurally who is more accurate?
a-modelling them as frame element acting in the centroid of the actual core , shear wall and making body constraints between the joints on the same shear wall or core of the storey
b-modelling them as vertical shell elements with the same shape as the actual walls
thanx in advance
thanx in advance
RE: cores and shear walls sap and or etabs modelling
ash060 ,about the connectivity to the slab with the shear wall..that's why we make body constraints between the joints acting on the actual shear wall with the storey joints of the frame element so those joints will have the same deformations
