33kV System earthing
Which is most common - Solid (or effective) earthing or Resistive earthing.
Thanks in anticipation.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: 33kV System earthing
IEEE141 indicates Resistance earthing is common for 5-15kV systems. I don't think this applies to system with overhead line distribution circuits.
Here in the uk the 33kv system is usually fed from 132/33kv Wye / delta transformers. This leaves the 33kv side un-earthed so a second transformer is introduced with a zig-zag primary whose star point is resistively earthed, an auxillary winding within the "earthing transformer" is used to feed sub-station house supplies etc.
The resistance value is usually set to allow a max earth fault current of 1000-1500 amps.
isquaredr,
Could you tell me whether the overhead line distribution at 33kV is common in UK or the arrangement you described is for cable distribution.
Thanks once again.
