Threads
Threads
I am currently using Wildfire 3.0 and would like to make a thread for a setscrew. I don't want to use the cosmetic feature.
Paul
RE: Threads
When you say 'make a thread for a setscrew' do you mean put a thread onto a model of a set screw...if you do then you need to do a helical sweep
Kevin Hammond
Mechanical Design Engineer
Derbyshire, UK
RE: Threads
Yes, I would like to put the threads in the model.
Sorry about that.
There is not thread command?
Paul
RE: Threads
Then use the helical sweep....only problem is that it is going to make your file size for that part rather big and consequently increase your regen time as well
Look thru Eng-Tips and MCADCentral for threads on helical sweeps
Kevin Hammond
Derbyshire, UK
RE: Threads
Thank you for your help Kevin
