Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Really appreciate your site. Really good site for learning what others do when they run into problems. You guy's are great!!!..."
Geography
Resonant Frequency of water moleculeHelpful Member!
Nigel (Aeronautics)
2 Jun 00 15:02
I am embarking on a study to determine whether a water molecule can be destroyed by forcing it to vibrate at is resonant frequency.  Any information will be appreciated.
Nigel Waterhouse
n_a_waterhouse@hotmail.com
A licensed aircraft mechanic and graduate engineer. Attended university in England and graduated in 1996. Currenty,living in British Columbia,Canada, working as a design engineer responsible for aircraft mods and STC's.
gregbell (Industrial)
29 May 01 10:20
That's how a microwave works. Just vibates at ressonance. You can make steam, but I doubt you'll get H2 and O2.
Rich2001 (Mechanical)
10 Jun 01 10:29
I have heard, but have not tested that by apply a frequency approx, 42KHz, H2o can be separated.
unknown (Chemical)
1 Mar 02 0:11
Approx, how many db's would it take to seperate the water?
jvega (Electrical)
1 Apr 02 21:18
I read that at 2,500 megahertz (2.5 gigahertz) radio waves are absorbed by water, fats and sugars. the mricrowave principle
Guest (Visitor)
22 May 02 18:35
If you could get the atoms in the molecule to vibrate at the resonant frequency with the bonds acting as springs, it would destroy the atom as long as the vibrations were not damped out before they could "add" to each other. Also, mocrowaves do not cause a molecule to vibrate like a mass-spring system, but to rotate and rub against each other. So the problem becomes how to get the molecules to vibrate like a mass-spring system.
rickg (Mechanical)
9 Jul 02 18:10
According to information at this web site : http://www.keelynet.com/energy/docx.htm
making water vibrate at its resonant frequency can be more than a little dangerous.  Use caution.
amart (Electrical)
21 Oct 02 14:22
The H2O molecule can be destroyed at 2000 grad Cetigrad, to achive that only heat is necessary.
mauk2 (Computer)
22 Jul 03 1:25
How do you plan to "make it vibrate"?
I have read up on extracting H2 from water, and thermally assisted electrolysis was discussed quite a bit.
According to some sources I read, water thermally decomposes into H2 and O2 at about 5000 centigrade.
If all you want is to crack water molecules, brute-force heat will do it.
Now, if you're looking for ways of generating hydrogen without the brute force method, using radio waves (microwaves) to crack steam might be an approach to try.
Just a few thoughts.  :)
Huggie (Electrical)
4 Aug 03 20:20
For a completely different spin on this, what happens when I strap on a 2.4-2.5 GHz headphone on?   Are the water molecules in my head resonating?  How much power is too much?
HamishMcTavish (Nuclear)
5 Aug 03 3:13
Surely any resonance that would happen on an atomic level would be damped out by macroscopic motion of the liquid?
Can a liquid HAVE a resonant frequency?
Could you explain a bit more of your theory?
Many thanks, HM
No more things should be presumed to exist than are absolutely necessary - William of Occam
Close Box
Join Eng-Tips® Today!
Join Us             Close
