ELF occurance
ELF occurance
I have been asked to investigate an ELF occurance. Several offices in the building are located above a 3 phase 460 volt transformer. Their computer screens flicker intermittenly during the day. The highest reading I got was 85 Gauss on a Extech 480823 electromagnetic field meter.
I have not found a yardstick to make a determination as to what's good or bad for human habitation.
Can anyone point me in the right direction?
Thanks for your help,
Phil
Phil
RE: ELF occurance
Flat panel displays will not flicker in EM fields.
RE: ELF occurance
h
http://www.who.int/peh-emf/en/index.html
RE: ELF occurance
There are no physiological effects that can, or does, harm human or animal organs or tissue.
That has been proven many, many times. And still, the nervous types are saying "Need more research". How much more? Ten times? Hundred times? The results will still be: There are no problems with ELF. I have been following this "meta-problem" for more than two decades. And all I can say after all these years is: The problem is in some individual's brains. Not IRL.
Gunnar Englund
www.gke.org
RE: ELF occurance
Phil
