Panic Hardware Definition
3
Regarding doors; what is "3 point panic" hardware?
RE: Panic Hardware Definition
I don't have any experience at all in specifying door hardware, but based on a quick Google search, I would surmise that it means an emergency exit rated door that latches at three points.
"3-point" refers to the number of locking points which are released by the panic hardware. In most cases it would be the top, bottom and side.
cheers
To expand a bit on CorBlimeyLimey's response,
"3 point" actually refers to the number of places the door is locked (usually for security reasons).
"Panic hardware" is an emergency release system to allow fast egress, especially under adverse conditions (such as a fire, gas release, steam release).
The "panic hardware" has to match the locking system hardware.  It does no good to have an emergency release system that unlocks two of three points on a door that has a 3-point locking system.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Which is usually provided by the crash bar mechanism on that type of door.  The crash bar has sufficient resistance to simple attempts to activate from the other side, but a small child has sufficient force to push the crash bar and unlock the door.
TTFN
