Insert Image in ACADLT 2008?
HELP!!
Does anyone know how to insert an image in ACADLT 2008? This feature seems to have been dropped from the program. I insert images for the following uses:
1) For the reasons we used to use stickyback;
2) scan a portion of a road map for use as a location map;
3) downloaded aerial maps from LABINS and overlay the site plan for exhibits;
4) scan aerial map with contours for drainage basin boundaries;
If I open a file that already has an image file then I can use it, but there doesn't seem to be a way to insert a new image. I had to use an older version of autocad to insert the image and then open it in 2008. That sucks!!
Any Suggestions?
Mark Schroder
Design Engineer
McKean & Associates Engineers
Any Suggestions?
Mark Schroder
Design Engineer
RE: Insert Image in ACADLT 2008?
David
Maybe the same in Lt2008?
Lothar
ADT 2004
Doug
DGCad
Where have I been? I started working at my current company in 2003 and have been using 2000i ever since. I'm amazed that they would eliminate such a useful feature. I guess I'll keep 2000i to use as an attachment utility.
Thanks for the quick response.
Mark
It will allow insertion of many file/image types, but not all. In particular, it won't do Mr. Sid.
http://www.lt-extender.com/LT%2DExtender/englisch/
____________________
Acad2006, Terramodel
