Sponge rubber removal from manifold pipe of HRSG
Dear,
It found case that during welding manifold use sponge rubber for supporting backing gas during weld process ( material P-91 ), the sponge rubber left in the nipple of manifold and no hand access to remove it.
Questions :
1. Can I apply heating (max. 1450 F) to help sponge rubber removing ?
2. If it still remainder left sticky at pipe wall, can it removing by chemical acid / cleaning ?
3. What kinds of chemical cleaning can I use ?
Regards / Bobby
RE: Sponge rubber removal from manifold pipe of HRSG
This doesn't help your present problem, but may prevent its re-occurance.  There are water soluble purge gas dams available.
