Ordinate Dim Text Rotation
Is it possible to rotate ordinate dimension text to horizontal from vertical?
Thanks!
Thanks!
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Ordinate Dim Text Rotation
Hope that helps.
Dan
www.eltronresearch.com
Changing the dimensioning standard still did not bring the desired result.
From what I gather, Ordinate dimension text is exempt from the given ANSI standard of all horizontally aligned text on a drawing.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
