Please offer your opinion
If you are in possession of a draft copy of API 650 Proof 1 January 2007 - refer to:
3.1.5.2 under Vertical Shell Joints par b. - "shell courses shall be flush-stacked on the inside"
3.1.5.3 under Horizontal Shell Joints par b. - "abutting shell plates at horizontal joints shall have a common vertical centerline"
Question - do you find these paragraphs contradictory?
RE: Please offer your opinion
Thanks for your response.
Do you design tanks with shells of different thicknesses within the same course?
FTank
Joe Tank
Application where plates in a course vary would be flush manway insert plates under older version of the standard.
There were a lot of changes.
