Two Questions on PEEQ
1.  What is the exact relation between PEEQ and True strain of the material that we define in *Plastic card.
2. When I change the mesh in the contact region the PEEQ value shoots from 8% to 22%. Why there is so much difference? I have an edge contacting an edge, so perhaps this is a singularity in the model?
http://web.peoriadesignweb.com/calculator
Online Engineering Spreadsheet Caclulators
RE: Two Questions on PEEQ
PEEQ is the equivalent (accumulated) plastic strain.
If you have two materials (different properties)  connected by interface displacement elements then you would have this strain-jump but the displacements and the stresses should be the same.. should not they..? please check and let us know..
