Hole Callout Text File
doing an edit of the Hole Callout text file - -and was wondering if there was an actual sheet somewhere that had the different variables named.
Thanks!
Thee Ox...thanks you.....and has left the building.
RE: Hole Callout Text File
Thee Ox,
Check out the very bottom of the "calloutformat.txt" file - it lists the variables used by the hole callout feature.
Killswitch
HOT DIGITTY!!
That worked!!
Thanks Kill
FYI, the calloutformat_2.txt file is a simplified version of calloutformat.txt
If you do any modifications to one, you may want to copy the mods (suitably changed) to the other in case you ever want to use the other version.
cheers
Will do, Limey - - -many thanks!!
