Conduction in Semiinfinite Solid
I am looking for the governing equations to calculate the conductive heat transfer in a semiinfinite solid. In my application I have a samll heat source that is buried in soil. I want to know the temperature of the soil at a given distance from the device.
RE: Conduction in Semiinfinite Solid
He doesn't give the temperature distributions, only the thermal resistance between the buried body and the surface R=(t1-t2)/q, t1 being the isothermal temperature of the body, t2 the temperature of the soil at the surface. The latter can't of course be uniform, so, though this is unclear in the book, I suppose that t2 is to be considered as an average temperature by which the subsequent flow of heat to the air may be calculated.
For a sphere of diameter D with center at distance z below surface:
R=(1-D/(4z))/(2πDk)
prex
http://www.xcalcs.com : Online tools for structural design
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
To verify calculations, I conducted a simple experiment where a resistor was placed soil. The resistor dissipated 4W. A thermocouple was attached to the resistor. After equilibrium, the resistor temperature was 89C. Based on this the therm resistance was 16.7C. Thus the calculated k for the soild was 1.19watt/m-K.
However, after further verification using an FEA model, I found that this k value is not correct. The K value that yielded model results that agreed with the experiment was 0.39watt/m-K. I further verified model results by placing another TC approx 1in form the resistor and the measured value agreed with the temperature probed in the model.
So, the equation initially used to predict k was incorrect. Is there another form of the euation that would yield better results (or another way to calculate k)
swguru
The equation you used is different than the one prex suggested. Because you didn't list your z and D values, I couldn't calculate which one you based your final k value on.
Prex's formula gives much smaller values, provided, of course, the diameter is less than one.
However, I think you hit on an important point. Most all of heat transfer is based on experimental results with the "formulas" being those that best fit the obtained data. I don't know how hard it would be for you to run additional tests. Then you could try variations on the R= ƒ(4z, D)/2πDk formula until you found one that best fit your data.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Additionally, if you left the setup alone, the results 6 months from now would be different than what you got, because the soil would have compacted and settled more.
TTFN
McAdams gives the following equation for a horizontal buried cylinder of length L, diameter D and axis at distance z below surface:
R=ln(4z/D)/(2πLk)
with z>>D and z<<L
or more exactly:
R=cosh-1(2z/D)/(2πLk)
with z<<L
What is unclear to me is the meaning of temperature t2 at surface of ground. If it is assumed variable, then it would be some average value, but then the exchange to air cannot be calculated as the area over which to calculate is not provided. It is possibly taken as constant (soil surface isothermal, as isothermal is the surface of the body), but McAdams doesn't clear up this point.
prex
I assumed room temperature for t2 since my soil experiment is in a lab.
Agree with IRstuff about k variability of soil due to compacting over time. Thsi is one of my big concerns for my actual application. Also moisture content would play a significant role.
swguru
