Pump Invention
Pump Invention
The inventor has challenged me to consider the type of design he has put together here. I believe the pump design to be patented, and I have seen some of his other designs, but I can't narrow it down - neither have other engineers I have posted this to.
They set up this handpump to test as a prototype. Try and remember that the whole thing is plastic, and designed to compete with the cheapest handpumps on the face of the earth. Make sure you look at Part III - that's the one that blew me away. I know that they opened up the tolerances to ensure long wear characteristics, but even with this the non-priming to 12 feet of water seems to be a pretty good vacuum.
I would have said positive displacement, except for the water leaking back through the pump. It may be that the water is running back through the tolerances around the crank (after all it is a cheap plastic handpump). Take a look at the four videos.
New Pump Invention: - http://www.youtube.com/watch?v=GN9KLd9X6ZE
Part II - http://www.youtube.com/watch?v=kV2mya8EkNc
Part III - http://www.youtube.com/watch?v=Tk-pq0Yoa4E
Part IV - http://www.youtube.com/watch?v=ztmcNISzaN0
RE: Pump Invention
Charlie
www.facsco.com
RE: Pump Invention
As has been said, check the US/UK patents offices.
