Copying a Feature
Copying a Feature
Copying a Feature
I am tring to copy a feature and when I get to defining the new references, the message area tells me
"Select FEATURE corresponding to highlighted FEATURE ."
At this point Pro-E will not let me click on any face, planes or geometry from the part.
What does this mean, and why cant I select a new reference?
RE: Copying a Feature
what kind of feature are you trying to copy? can you give me some details or example?
i am just trying to copy a simple extrude from one face to another
ok, what it wants is references, it will highlight a feature from the orginal part and all it wants is the new  reference for that particular feature on the new part. example:
if it highlights an edge that an dimension was attached to from the orginal part it just wants a new edge on your new surface to attach the same dimension to. hope this helps, if not i can get more specific.
