Model equal length exhaust header
Can anyone give me some hints about modeling an equal length header system in Pro/Engineer. Obviously I have multiple starting points and a desired finish point that is a packaging constraint, plus the volume that the finished item will take up (or area that will be allocated for the exhaust system)and each curve will be equal lengths.
Suggestions
Steve
Suggestions
Steve
RE: Model equal length exhaust header
http://www.profilesmagazine.com/p28/tips_asim.html
http://www
http://w
http://www.profilesmagazine.com/p29/p29.pdf
