What flat panel monitor are you using?
I was looking into flat panel monitor for our solidworks users. So I was wondering what others are using and/or recommendations. I was looking at the Viewsonic VA1903 19inch displays. Any thoughts ?
RE: What flat panel monitor are you using?
Go with the widest you can afford. Some of our people have the 24”. Their productivity is up 10% from before. That is compared with me on the small 19”, less zooming in and out.
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Tony
HP NW9440
2 GB RAM
Quadro FX 1500M (84.88)
SolidWorks 2006 SP5.0
Solidworks 2007 SP1.1
JEM
Solidworks 2007 SP3.0
2GB Ram/3GB Switch
Quadro FX1300
P4 3.40GHz Duo XP Pro SP2.0
Blew my frickin socks off. Set me back around $500 CDN, but I haven't once regretted the purchase.
Specs, Intel Pentium M 2.16 Mhz
SW 2007 R2.2
1.5 Gb Ram
NVidia GE Force GO 6800 256Mb
another interesting thing is that a 22" widescreen is the same physical height as a 19" non-widescreen. (just 3 or 4 inches wider.... res 1680x1050 vs 1280x1024)
SW 2007 R2.2
1.5 Gb Ram
I tend to dock more toolbars vertically... also the command manager, I dock on the left vertical side. So a wide monitor works best for me. Plus the feature manager is on the left vertical side & it ain't dockable (yet).
Do get both monitors that match in size & resolution. Mine are mis-matched vertically & my mouse sometimes gets "stuck" in the lower inside corner of my tall monitor.
But I have no specific reccommendations for you.
Windows XP / Microsoft Wireless Optical Mouse 5000 / SolidWorks 2007 SP2.2 / SpaceBall 5000
www.Tate3d.com "Right-click. It's friggin' magic!"... Jack L. Tate
FAQ376 I'm famous.
Would you like the number for 911 also?
flattie with a cordless mouse and keyboard....does that count.....??? It's like heaven.......lol
Here at work it's a 19" LG sumtin sumtin....not bad, love
the reclaimed desk space tho.....
Dave
http://
If you go with an LCD, there are lots of things to consider. A big one is that darker colors (grays) tend to wash into the same indistinguishable color on monitors of less quality. I went from a ViewSonic 21" CRT with amazing color clarity to this one with great hesitation because of this display issue. But in checking the Gateway "in person", I found this treats color very well (important because of all the rendering/animating I do--need to nail the color on this stuff, and not lose detail in the shadows).
Also, with this monitor, if you're designing rockets it would work great. Just rotate the screen 90* and it figures it out. Plus there are all sorts of connections in the back and I think it's supposed to work with Vista (if you ever make the mistake of upgrading in the near future) because of the HDMI technology (or something like that). I use the DVI cable with my machine--super clear.
Read the reviews--and find more current ones than what I posted above. You'll then make the best choice for your particular needs. Dell has killer deals on their stuff right now, but good luck getting a good look at one of their displays before buying (I highly recommend looking at a real monitor before making a purchase).
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
One is for SW, the other is for "other tasks".
(I tried SW across both monitors and did not like the results)
I believe that this is a sufficient size and a good "bang for your buck" type deal, but then I am not designing rockets either.
For me good qualty was a little more important size
(where have I heard this before??)
kd1959
Solidworks 2007 SP3.1, PDMworks
4GB Ram,3GB switch
2x AMD Opteron 254,2x 19" Viewsonic
Quadro FX 3400
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
They may not be the absolute best but unless you have a really keen eye it is hard to tell the difference, I certainly cannot.
Despite having UPS backup we did have one “blow” in a thunderstorm (it may have been coincidence) and they replaced it next day, no questions asked. Delivery is always very good as well, two days is the longest we have waited.
For price and service they are second to none IMO.
