Intergraph PDS RDB for tubing
I was wondering if anyone has Reference Database (RDB) library information for tubing products that can be used with Intergraph's PDS software.  The products would be the various fittings and valves typically used in instrumentation lines.  I would not think that this information would be proprietary or copyrighted since the info would basically be dimension tables with values coming from the catalogs.
I know we may be crazy even considering to model the tubing in 3D, but that is the direction we are headed.
any information would be appreciated.
thanks
Mark
RE: Intergraph PDS RDB for tubing
Wow- you guys are intent in throwing away a significant advantage of using tubing in the first place- the fact that it can be easily field-run without the need to spend time doing routings and modelling it!
