Two well pumps in series
Dear friends ,
I have a water well , 250m depth , with 10" casing, the allignment of the well is checked by 8" pipe , the pipe stucked at 170m, another allignment test is performed with 6" pipe and the pipe reached the bottom with no stuck. due to this bad result it is recomended to use a pump which has a daimeter less than 8".the flow capacity of the well is about 70m3/hr , with 190m head. and the pump setting is decided to be at 230-235m. I looked through many suppliers cataloges with no result of standard pump that can give the required operating condition due to the small size of pump diameter that can be used. Inaddition we will not use 3000rpm motor , only 1500rpm till 2000rpm. some people advised me to use two submersible pumps in series but I didnt use this type of installation before and I have no experience for the two pumps installation , can you help me with some of your advice or any precautions that I need to follow to install two pumps in series .
Thanks for all your input
RE: Two well pumps in series
What conversion do you need? metric to American standard or vice versa? English language to some other language?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
190m to ft head x 3.28 = 623
If a 9 inch pump won't fit, you'll have to accept 3000 or 3600 rpm.
You'll have to compromise.
Assuming you are in a 50 Hz electrical environment, there are 6" pumps that will do what you want at 3000 rpm, but you will also have to find a 6" motor to suit. And the pump will be something like 20 stages.
Why can't you use a 3000rpm unit? Nobody is going to hear it 200m down the hole? Just get it, put it down at night time when nobody is watching, and watch all the smiles when the system works.
Does anyone of you have any experience regarding the installation of two pumps in series , I need some input and what things I should take care of it
http://virtualpipeline.spaces.msn.com
Let's assume you're in a 60Hz electrical environment, so your max desired speed is 1800 rpm. For a 7inch submersible, you are limited to about 350-400 gpm. Adding stages or pumps in series will do nothing to get you a higher flow.
That said, if you do, for some reason, want to put two submersible pumps in series, you will have to design casing to allow the water discharged from one pump to flow past the motor and into the suction of the second pump. You will be constrained by the physical space in the well and the size of the motor, along with the liquid velocity past the motor.
There is no way you can physically "join" two 6" pumps in series down the hole (I don't think)!
If the client does not want 2 pole motors then the client does not want 2 pole motors.
As for a way to do this, take your first 6" pump and motor and install it normally with a 6" pipe riser, this riser would be span from 230 meters to 170 meters. at 170 m the a reducer would expand the pipe to 8" (some would call it an expander) and 10+/- meters of 8" pipe would be installed (the 8inch pipe still fits there). Inside the 8" pipe, the next 6" pump and motor is installed. the 8 inch pipe would extend beyond the 6" riser of the second pump. I would install a fail safe level switch inside the 8" to ensure the second pump has water to pump. I would also size the second pump to pump less water than the first pump so that some water would overflow out of the 8" pipe and back down the well. the 8 inch pipe would be welded to the 6" pipe with tabs, so the first pump is also supported by the drop pipe.
do-able, but worth it???
The control system would need extensive logic to ensure the safe operation of both pumps
Hydrae
Also, since the motor on a submersible pump is below the inlet, in your scenario, the inside of the 8" pipe will have a 6" motor in it; the 600 gpm is going to have to flow in the diametral space between the outside of a 6" motor and the inside of an 8" pipe.
That's not much space; what, about 22 square inches...600 gpm...that's a velocity of what, 533 ft/min????
The correct flow is, of course, 300 gpm or so.
So the velocity in question is what, 250 ft/min or so.
Controls are the killer with this system. You have to turn the lower pump on first and then just as it reaches shut in you turn the second pump on. Start too early and the second pump cavitates to death. Start too late and the bottom motor will burn up.
You also have to have very good restart protection. It will take a long time for the string to drain before you can turn the motors back on.
Tell them too get over the speed hangup. You don't have enough annular space for the canned upper pump. I used to build pumps, this unit is 11,000 BPD. Not small. It can be done at 3500rpm (60HZ) with a GN10000 and an 80hp motor.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
" Windows can multitask poorly; some of us can multitask just as poorly."
I know how you feel :)
