AASHTO Load Cases
AASHTO Load Cases
Does anyone know what the standard governing load factors are for concrete bridge slabs designed with AASHTO LRFD? I have read that it is 1.3DL + 2.17LL and I have also seen 1.25DL + 1.75LL listed. And I have even seen 1.3DL + 1.3LL. Which of these is the latest governing load case in the current AASHTO LRFD? Again, this is for a check on a concrete bridge slab.
On another note, is the phi factor calculated as it is for regular LRFD for concrete (steel strain above 0.005, than phi = 0.9)?
RE: AASHTO Load Cases
Phi = 0.9 sounds correct.
Good Luck.
BTW, there is a bridge engineering forum here also.
