How do you lubricate Vertical Turbine bearing?
Hi all.
Now I am buying a vertical turbine... but there is a kind of problems in it. According to vendor's specification, the lubrication type is oil. If you have oil lubrication type, plaese let me know your experience...
RE: How do you lubricate Vertical Turbine bearing?
Please give us so more information.
What kind of turbine? What kind of bearing?
Thanks QCE.
I am a mechanical engineer working for refinery & petrochemicals.
That is the steam vertical turbine and uses ball bearing.
