a way to change version of proengineer Wildfire 2 to proengineer 2001
Hi everbody.
I-m looking a way, to change the version from PROE Wildfire to Proengineer 2001, exist a way to translate? with the command like proe, not like steep
because some company that we work, they don-t work in wildfire. so if anyone can help me??
thanks you!!
thanks you!!
RE: a way to change version of proengineer Wildfire 2 to proengineer 2001
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
But you will get dumb solids, like Heckler said.
-Hora
Article on using .Neu Neutral Files
http://www
Both links are identicle but the second one you can copy the path for directly. I suggest using Save Target As in case the page gets moved.
Michael
