Thread Callout
Thread Callout
Thread Callout
Is there a way to specify left or right hand threads when using the hole wizard?
John
RE: Thread Callout
Thanks for the reply.
I tried to search for this yesterday but every search I tried came up with the No threads found message.  Don't know if there was a problem on my end of if the board was doing maintence but glad that you had a link.
Hopefully the direction of thread will be added into SolidWorks.
RE: Thread Callout
Submit an ER if you want it added to a future version.
The regular Search function has not been working for quite a while now. Use the Google search at the top centre of the page, with the Eng-Tips Forums option selected.
cheers
RE: Thread Callout
Thanks.
Guess I should use the forum more often. =80
