Linking into drawings
I am trying to populate fields within a drawing automatically.
I carnt quite find the comand to do this. Help points me at a specific text button but it doesnt work in the background view.
Ideas?
Ideas?
RE: Linking into drawings
If it has and you are still having the problem, what specific information, i.e. from what property of what file, are you trying to link to the background sheet?
--Scott
http://wertel.eng.pro
when, for instance you have set the callout to show the
title of an item i.e. %{Title|R1} and placed this on a background
sheet then it will show "Error no reference". This will be
replaced by that information that the source part holds
within File --> FileProperties --> Summary --> Title. This
may be a space, however.
You must, however, use the Callout not the Text function
for this to work. This has already been mentioned by swertel
dy
To be added:
The error text will be replaced as soon as you place
the view of a part.
In my opinion - not a good idea to use a space as the place holder for call-out text. I would use a # or - so that you can see them.
I've seen too many multiple copies of property text fields created on drawings because a space was used and users couldn't see them, especially inexperienced users.
bc.
... tell it UGS, a space is the default value for those
items (all items with a pulldown) after installation.
dy
or change the normal.xxx to any desired default value. Also
possible is to use the propseed.txt to populate some
properties with a default value
Ok next thing is i want to have some set values that the user MUST fill in before saving the drawing. Ive looked at propseed to dot his and it seems ok for the drop down box in the custom section. However it would be nicer if i could have it layed out like the sumary tab. Any ideas? Also any ideas on how to make it so the user has to select something?
Also noticed a tick box for hardware part. what does this mean?
The checkbox for hardware part deals with upline drafting. Specifically, do you hatch hardware items: bolts, screws, nuts, washers, within a section view or not? Some standards don't, others do. This checkbox allows you to control that at the part level instead of having to do so at the drawing level - when you may have dozens of the same fastener sectioned in a view and you have to individually turn off the hatch in each one.
--Scott
have yoy manages to get custom fields anywhere else appart from the cutom tab?
also any tips on transfering the data to access?
Is there a way to show the property text for the part/assm that is currently being displayed on the draft view in a multi-page draft?
