Circularity vs Circular runout
Can anyone explain the difference between the two and can they be used on a print interchangeabilty? I have a customer that is telling me that I have a problem with the roundness of a inner diameter. He wants to put a circular runout back to another datum (opposite end of part - inner diameter). Any thoughts?
RE: Circularity vs Circular runout
Circular runout is also placed on a cylindrical feature whose centre line is also shared by another diameter which would be the datum. One would place the datum diameter in a divider head (chuck)while the digital indicator is place on the highest point on the cylindrical feature. Rotate the part and report the TIR or FIM (depends where you live). It is a bit trickier than that but it oes confirm a combination of roundness and off centre condition. Roundness is a component of circular runout.
Dave D.
www.qmsi.ca
Circular runout requires an axis derived by a feature or feature(s) for its measurement. Therefore Circular Runout controls the variation of the surface of revolution for circular form and location simultaneously and since there are infinite places along the axis that must conform it controls orientation as well. It does not control size so it does not control cylindrical form (a cone can have perfect circular runout).
Just cautions: If the two cylindrical surfaces are nearly coplanar and one has sufficient depth to establish a stable and repeatable axis for measurement then the circular runout callout may work well but if the two cylindrical surfaces are relatively shallow and widely seperated from each other (as I imagine from your post)then there are better ways to dimension and tolerance these surfaces relative to each other.
Paul
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
