cam paths/mates
cam paths/mates
cam paths/mates
Hi all
The curve created by the cam routine uses a series of points to generate the cam path. The resultant curve cannot be used to mate any type of follower to produce motion.
Any ideas on how to change all the points to a continuous curve? Thanks
RE: cam paths/mates
Fit spline (try two halves for ease of mating). Or u could use a sketch (centered in the track) and constrain to it.
RE: cam paths/mates
br17-Fit spline, great. Thanks
