Fire Water Jockey Pump Electrical Supply
My project involves upgrading an existing industrial fire water system. I am adding a diesel powered pump and two electric jockey pumps ( all with controllers ) to a system which has an existing primary electic pump and two backup diesel pumps.
Are the electrical wiring code requirements for the fire water jockey pumps/controllers exactly the same as those for a main electric fire water supply pump/controller? i.e. Power source, wiring, controller placement?
RE: Fire Water Jockey Pump Electrical Supply
