Coefficient ratio exceeds 10^8 - check results
What does the warning: "Coefficient ratio exceeds 10^8 - check results" mean?
Pingen
Pingen
RE: Coefficient ratio exceeds 10^8 - check results
I suppose it is the ratio of the biggest to the smallest coefficient in the compliance matrix. But I'm not very sure of that. It's just a guess...
If your model has two very deferent materials, with large ratio of the Joung-Modulus, then the coefficient ratio should also be large.
I would also like to know, what the other people on this forum know about this.
Alex
Cheers,
Pingen
