Checking for Interferences in a Weldment?
Is it possible? I am building structures using square and rectangular tube using the weldment feature. I have to go around after and make sure all corners,etc. are trimmed and sometimes I miss some corners. Is there a tool to help with this , much like the assembly interference detection tool?
RE: Checking for Interferences in a Weldment?
1) Switch the view to wireframe. Sometimes it is easier to see if lines intersect that way.
2) Use the Combine function with the Common and Show Preview options selected. As bodies are selected (usually only two at a time unfortunately) any interference will be highlighted.
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
You can do multibody interference checking. Just put your multibody part into an assembly and run "Interference Detection" with "Include multibody part interference" option.
Good Luck!
Alex
Bradley ... You don't like Weldments?
I love weldments. Our machine shop is requiring us to draw each piece, so they can machine each piece on a mill. Then they weld it up.
I was wondering if anyone else did this?
Bradley
That would have been a good idea. We have to detail out each item as piece part and dimension.
Bradley
Thanks for the star! I feel good of earning a star from a fellow forum member like you. By the way, how do I give a star to fellow forum members when I post a message?
Alex
