Help with IF statements
How to I write the following in MathCAD?
If Pr >= 0.51 and Pr <= 0.7 then Scf = 2.4 + ((Pr-0.51)^3 * (3.82))
If Pr ? 0.70 then Scf = 3.125 + ((Pr-0.7) * (8.25))
CadLady
CadLady
RE: Help with IF statements
If a is true then the returned value is b, else the returned value is c.
For example:
Scf:=If((Pr>=0.51)*(Pr<=0.7),((Pr-0.51)^3*(3.82)),(3.125+((Pr-0.7)*(8.25))))
For AND and OR operators mulriply or add boolean operators, the example abocve shows an AND operator
(Pr>=0.51)*(Pr<=0.7)= (Pr>=0.51) AND (Pr<=0.7)
where as
(Pr=0.51)+(Pr=0.7)= (Pr=0.51) OR (Pr=0.7)
Hope this helps.
Fawkes
Write 'Scf:=' then press '}' (curly bracket) this will open a conditional object. Write the answer then press SHIFT+} to start the conditional statement (MatchCAD should automatically write ' if '). Use the arrow keys to move between different rows in the equation.
Any problems check out the help for Conditional Statements.
Fawkes
What do you mean by "pr?0.7". Is the "?" supposed to be <,=, or >?
More help to follow when I know what this means...
Imagineer
Quite right, sorry, press the square bracket first.
Fawkes
