Add block at cursor
Add block at cursor
Add block at cursor
In order to add a block reference in a drawing using VBA the code is
ThisDrawing.ModelSpace.InsertBlock Pt1, BlockName, 1, 1, 1, 0
but that assumes that I want to put it in a specified location. How can I bring the block in on the cursor so the user can place the block wherever they want it?
RE: Add block at cursor
I do a similar thing. I do a insert and then a move command. The user never knows the difference.
http://mechcad-insider.blogspot.com/
"The fear of the Lord is the beginning of wisdom"
You can use utility.getpoint to get a point, but you won't get the block to 'ghost' with the cursor.
It's pretty hard to get that using VBA. It's easier to obtain using LISP.
The other alternative is to put the block in a pallet. This will create a button that you can use to specify layer, scale, rotation etc.
Thanks so much for your help. I think I'll just move it to the correct location after I create it.
Yes- That's what I'd do. Have your code insert the item, and move-last, then "@" for last point used (insertion point) and pause for next user input. The block should appear at the cursor, with the next pick being the drop point. If you don't want rotation, [enter] past that step and close the command.
I run this very operation as a simple macro, with the above steps. Don't know the exact code you'd use for Vb, but this is the logic, anyway.
Good luck-
C. Fee
