Tips on types of cooling towers
I’m looking for some tips on different kinds of modern cooling tower-type to use for cooling of water used as cooling water in a chemical process plant. The Capacity of the tower should be at least 25MW, cooling for example 2000m3/h from 36 to 25ºC. I would be very thankfull for any tips on the type of cooling tower to use as well as manufacturers, homepages etc.
Thanks for your help!
RE: Tips on types of cooling towers
ht
HTH, dogtop
Jonas82:
If you are unfamiliar with large industrial cooling towers, you might find it very useful to read this article:
http://en.wikipedia.org/wiki/Cooling_tower
Milton Beychok
(Visit me at www.air-dispersion.com)
