Unconnected regions Urgent
Hi Everybody
I imported an iges file and i load an analysis, it appears in the warning box the following message: 6 unconnected regions which is followed by a lot of negative eigenvalues.
I tried to repare the model but the problem is remaining.
Is there anybody who canb help me please ?
Nadir
RE: Unconnected regions Urgent
If they're seperate parts then merge them into a single part in the assembly module or just tie them
corus
Thank you corus but it is a single part
Look in Viewer to see what the unconnected regions are. Unconnected regions can refer to surfaces that define a  contact surface for instance.
corus
ok
thanks
