Selecting parts
Selecting parts
I'm working on an element model which I have transfered from WB to Classic. The model is an assembly and Ansys shows the different parts in different colors. What is the easiest way to select one of these parts? Since Ansys gives them different colors, it seems reasonable to think that each part can be selected as a unit.
Pingen
Pingen
RE: Selecting parts
remember that you don't have any solid model entity in Classical when you transfer it from WB. However, different Element Type Numbers are assigned to each part of an assembly, even if the element formulation is the same (SOLID186 or SOLID187).
So, the easiest way is to ESEL,s,TYPE,,nnn where nnn is the Element Type Number corresponding to the part you need to isolate. In order to see which ETN has been assigned, one way is to PlotControls -> Numbering -> By Element Type + Colors-and-Numbers.
RE: Selecting parts
-Brian
RE: Selecting parts
Pingen
