Booster Pump
Booster Pump
I am worrking on a fire sprinkler design on a new shopping mall bordering 2 streets, one on east side one on west side. There are 4 separate 4 story retail structures above 60,000sf common shopping mall. They share common address. One of the 4 structures is open parking structure. The roof top of the parking structure is used to park cars and is considered a level and I was required to design a Class II Fire Hose system 65 psi @ 100 GPM. in addition to 5-Class I Standpipes for parking structure and other Buildings.
Structures have passed building plan check and they are
not classified highrise. The city water pressure at street
level is 90 psi.
Here, I am going back and forth before sizing a fire pump to deliver 65 psi at the Class II Fire Hose Cabinet.
System components(ex. Fire Sprinkler Heads)rating is
at 175 psi if I am correct and have to make a resonable judgement not to exceed this pressure if I am also correct
as over rated system components are special order. Besides, I have no idea what additional measures will be required to over reared sprinkler systems. If I select a fire pump say 85 psi@750gpm, am I going to be on a safe side, seriously?
any experienced comments?
nathan
level is 90 psi.
nathan
RE: Booster Pump
If you are not a highrise, can you have your standpipes be a manual wet? That would save you the pump?
If you must have a fire pump, you will need to check your pump curves and see what you have at churn, but you are probably looking at 70 psi max for a pump. That is assuming 120% at churn.
