New Staad 2006 - beam
im trying to use the new staad 2006... im using a beam 30ft wide.. uni DL 6k/ft ...uni LL 2k/ft... i selected a randomn section... im using Code AISC Unified method LRFD... when i put select all and code check all it only shows what section passes but how do i show that the section that i initially picked fails and reasons why it did.??
RE: New Staad 2006 - beam
Try removing "SELECT ALL".
