Solidworks 2007 cpu usage
Hi
i use Solidworks 2007 at my office,but sometimes the CPU usage level jumps to 100% on one of the cores and remains 100% for some time (I'm using Dual core 3.4GHz). any one having the same problem?
RE: Solidworks 2007 cpu usage
Sure, we all see it from time to time, it all depends on what you're doing at the time.
What are you doing when you see your usage jump?
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Arash
I have been battling this for weeks now.  We switched to quad core cpu's and the new Nvidia Quadro 4600.  Under normal operation I can be doing something as simple as spinning a part around for a better view.  When out of nowhere the the cpu jumps to 25% (maxed out one core?) and I can do nothing with SW for 15-30 seconds.  This happens every few minutes.  I can get rid of the problem when in Software OpenGL mode, so I suspect the video driver, the Quadro 4600 is under it's first and only driver, so I'm sure it is nowhere near SW cert.
What is mind boggling is we have 6 identical machines and mine is the only one with this problem.
SW/PDM 06 4.0
Sorry to keep bringing this thread up to the top, but I figured out the answer to my problem.  When I brought it up to my VAR, turns out this same thing has been causing them problems, like white/black screens and hangs.  I had been running in software OpenGL mode, but the real culprit was Microsoft Intellipoint 6.1 for XP x64.  As soon as I disabled the ipoint.exe process, my hangs went away.
Welcome back hardware acceleration and realview, goodbye extra mouse buttons.
Also I found out it's nearly impossible to submit a bug fix request to microsoft.
SW/PDM 06 5.1/5.0 x64
I had similar issues but not using SW, I just wonder if this is strictly a SW issue.  You may want to consider these diagnostic steps.
In WinXP, I discovered that there is a documented bug (well, there's a bunch  of 'em).  An internal program 'svchost.exe' used to load & execute .dll executables went beserk and maxed out the CPU.  PC locked up completely.  On another PC I Googled for the answer and found out how to attack the problem.  I finally figured out that during boot I could start Task Manager and watch the multiple 'svchost.exe' processes running.  When one of them would start to spiral out of control (CPU usage => 100%), I'd kill that process.  That allowed me to get the Microsoft Hotfix update.
TygerDawg
TTT clown
I was having the same problems with my setup. I'm running winxp pro sp2.0 and SW 2006 Sp5.0. I disabled Ipoint.exe and all is fine. I had the same black and white frozen screen as was reported beforehand.
How do you disable the ipoint.exe? sldwrks is running so slowly on this computer it is unuseable.
The slowness of SW on your machine is probably not mouse related. The iPoint problem causes freezes and hangs, not general slowness.
What are you system and network specs?
What other programs/processes are running?
You should probably start a new thread with the responses.
cheers
