Torque needed to turn steel shaft
My mind has drawn a blank. I need to determine the necessary torque turn a steel shaft. The shaft is 7" in diameter, 36" long, and weighs approx. 400 pounds.
What torque is necessary to start from a stand still. I only want it to turn at 15-20 rpm.
RE: Torque needed to turn steel shaft
that will determine static friction (stiction?) and dynamic friction.
is the shaft connected to anything? if not, why bother?
has your brain unstuck yet?
Jay
Well my brain has partially unstuck. I am trying to make a polishing stand for large shafts. I am going to use heavy duty casters inverted with the work piece resting on top of them. I will be driving 1 of the 4 wheels with a belt pulley setup connected to a motor/reducer. The bearings of the casters are roller bearings.
I think I will need approximately 300 in/lb torque.
what will you use to do the polishing?
will it impose a torque on the shaft?
(I hope you have some kind of lift to load/unload those 400 lb shafts!)
Jay
Yes we do have a 5 ton over head crane for use in loading the polisher.
Ken
