Sewer line depth bellow concrete
We are doing remodeling of a building. I have the plumbing floor plan of existing. How can I find out how far the pipe is bellow the finished floor at any given point. At the floor drains it should be at the depth of the p-trap?
Fred
Fred
RE: Sewer line depth bellow concrete
How precise of a depth do you need?
thanks for your reply. The accuracy of +/- 6 in. is good.
I want to lay a new drain pipe and tie into an existing. I am just afraid that at the point of intersection, the new line might end-up to be lower than the existing line. How do do I plan so they intersect and continue to drain.
regards,
