Drawing Graphics Issues
Happy Friday Everyone,
I'm having graphics issues with drawings I'm working on. It seems when I re-open the drawing the geometry is falling out in certain areas in views on a multi-sheet drawing. I updated the graphics driver yesterday though the SW site, but still having problems. One of my co-workers just loaded SP 3.1 for testing, and opened my same problem drawing with no luck. The only work around is to toggle between “Draft Quality” and “High Quality” and seems to temporally fix it. When saved and re-open the problem is back.
What really bothering me is that when DC releases the print, they won’t know to do this and the drawing will be pictorially incorrect.
My drawing views are created from a SW assy and I added splines in the views for wiring paths (working on a harness assy). Could this be the problem?
Macduff ![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
RE: Drawing Graphics Issues
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
I'm looking at the Tools>Check>Check Entity and seems to have a lot of options. I used the defaults and it checked fine. When I selected some of the other options, I start to show results in the "Results List". Is that the problems I need to fix?
Colin
Colin Fitzpatrick
It was worth a try!
www.scottjbaugh.com
Best,
Colin
Colin Fitzpatrick
