I am new in Adams/view
I wish to know more about .adm and .acf files. If we use graphic based of 2005r2. how can I track or define for example contact. I have already in an sysmterical model defined contact (solid to solid). from both side I measure the magnitude of my spheres when they collide. for both side start the same, but in middle of the optimazation, the length slightly change in second digit in calculating the magnitude of distance, and then all of the sudden the contact force in one respond and the other never comes to a contact.
I figured looked at the .adm file is the best way to see that.
if you could tell me, how can I generate one, I appreciate it.
thanks,
thanks,
RE: I am new in Adams/view
export
adams/solver data set
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
