Cascade, Secondary, and Indirect refrigeration systems
It seem to me that a cascade refrigeration system is the same as a secondary refrigeration system and also the same as an indirect refrigeration system.
I see no difference between the secondary and idirect methods.
Are they the same type of refrigeration system?
The only thing possibly different in the cascade refrigeration system is the cascade heat exchanger.
If so, what make the cascade heat exchanger different from the heat exchanger used in a secondary or indirect refrigeration system?
Thank you for your help and the time you took to answer my questions.
RE: Cascade, Secondary, and Indirect refrigeration systems
respectfully
