Draft Dimension Shifting on Drawings from design table
A simple part family was created (part looks like a ring). The ring consists of an extrusion with 2 cuts, one of which has a draft angle of 10° from vertical on the inside. Everything looks in order in the model, and when changing parts in the model the angle is always dimensioned from the appropriate point. A master drawing was created and the autdimension feature was used in placing the dimensions. All dimensions are in the correct location. When the part is changed they move to thier new location based on the references from the model. However, the 10° draft angle will not move, and is out of place on most of the different size, and can not be moved. Any help appreciated. Thanks in advance.
RE: Draft Dimension Shifting on Drawings from design table
Can you zip and post the files?
FAQ559-1177: How Do I Make Files Available For Download? ... No Emails Required
