Mating Assemblies
Mating Assemblies
Has anyone figured a way to mate a hole from one part to an elongated slot on another part or am I just missing something. Concentric won't work with an elongated slot. I have tried inserting sketches and mating the sketch from one to the other and still no luck.
Thanks in advance
Thanks in advance
RE: Mating Assemblies
Scott4tg
ht
Thanks again!
Scott4tg
Scott4tg
Then turn on the temporary axes in your model (View > Temporary Axes). Mate the temporary axis of your hole or bolt to the point in your slot sketch.
I do this when I first create the slot. You will get the construction line for free if you use the technigue of the bi-directional with capped ends offset line feature technique to create your slot. You can save the slot as a library feature so the construction geometry will always be in your slot feature every time you add a slot to a model.
Anna Wood
SW 2007 SP2.2, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
