Sawtooth Rack
Sawtooth Rack
Does anybody know where I can purchase a sawtooth rack for a rack & pawl assembly? It's for reverse travel prevention. The best I can describe the mechanism is that it's the main functioning characteristic of a common jack stand that you put under your car. I need to bolt one between two linear-motion parts to serve as a safety feature and it has to be about 4 feet long. Standard racks have 14 1/2 or 20 degree gear faces. A sawtooth has a zero degree face on one side and some aggressive face angle on the other. I've seen plenty of rotational ratchet/pawl devices for sale in typical supply houses, but the linear version is looking like it has to be a custom make thing. Any help locating one of these for purchase would be greatly appreciated.
Concept
Concept
RE: Sawtooth Rack
TygerDawg
RE: Sawtooth Rack
Ted
RE: Sawtooth Rack
The inside angle of the teeth is acute, so they can't be machined with an ordinary end mill. If you design them to be greater than 60 deg. (or, ideally, *exactly* equal to 60 deg.) then you can use a dovetail cutter in an angled mill head. The smaller the angle, the finer the pitch of the ratchet for a given depth. If the ratchet is big enough, I guess you could also mill it from the side with a regular cutter, but you would have filletted roots.
Another option is to design it with a rack and pinion and put a circular ratchet on the pinion shaft. You might also consider an overrunning clutch like a sprag or roller clutch, but you would need to design a release mechanism, since you would no longer have access to the pawl.
Don
Kansas City
RE: Sawtooth Rack
Thanks for the input.
Concept
RE: Sawtooth Rack
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
